Solar Goes Green Solar LED Spot Light
The brightest outdoor solar spot lights available on the market. This heavy duty fixture is packed with 12 high powered LED bulbs, and is made from a pro-grade cast aluminum. This light is a perfect solution for your outdoor lighting needs. Whether it be for solar garden lights or for getting a feel for how solar light has a practical application in your everyday needs, this light is a great solution. The Solar Goes Green S12 Solar Hi Intensity Spot Light with 12 high powered super bright LED bulbs (light source) . The light fixture and solar panel is connected by a 1 ft cable, allowing ideal positioning of both. Three mounting options available to assist you in making sure this will illuminate your flag, statuary, signs, walls or open areas correctly. Fixture fully adjustable to point beam in any direction desired Reflective casing provides powerful spot light Turns on light automatically at night Light illumination will last 8-10 hours based on full charge Manual Off Switch - allows for light to stay off Perfect for lighting flags, trees, signs and open areas such as driveways, decks or walk ways Water and Weather Resistant Warranty: LED Lights - 3 years Wall mounting hardware included. Dimensions: 10 L x 10 W x 3 H; 3 lbs.
